MAG251RX VS VG259qm what to chose
aditrex
Post by aditrex » 22 Jan 2022, 05:22
MAG251RX VS VG259qm help me decide betwen those two monitors i can get MAG251RX for 300eur and asus for 330 eur i im corrently using mag274qrfd-qd i love this monitor so much excelent monitor just i cant get used to it i think it is to big for my case use that is mostly FPS games like apex legends and battlefield... i have only one negative on this corrent monitor when transition to white it does comes to bright to shiny my english is bad so cant explain the best sorry for that but i do think it has only issue that is very distracting... from my research it seems that mag251rx is using pretty similar au AHAC panel like the bigger brother does just want to know if small brother has less issue with white background thank you guyz in advance for help
IIISLIDEIII
Re: MAG251RX VS VG259qm what to chose
Post by IIISLIDEIII » 22 Jan 2022, 09:48
I wouldn't take either of the 2 if your goal is just a shooter whit minimum blur
MatrixQW
Post by MatrixQW » 22 Jan 2022, 13:23
Then what monitor is best for minimum blur? (without strobing)
Are there any 240Hz monitor(s) that have an average response time of 4.16?
IIISLIDEIII
Post by IIISLIDEIII » 22 Jan 2022, 13:49
MatrixQW wrote:
22 Jan 2022, 13:23
a good tn will have much less blur than any ips.
Among the best tn without mbr:
-omen x25 or ozone dsp24
-if you like mbr (it sucks to me) xl2546k
if you have to stay on an ips the only one that is worth today is acer xv252qf, it will have blur but at least it has a very low input lag and excellent fluidity thanks to 390hz
aditrex
Post by aditrex » 22 Jan 2022, 15:49
IIISLIDEIII wrote:
22 Jan 2022, 13:49
MatrixQW wrote:
22 Jan 2022, 13:23
thanks for advice forgot to mention im not into TN panels dont like the flat look id take slighty worse pixel responsivnes over poor image... but after reading alot things on this forum i already decided on msi monitor already ordered
