This is my first OLED display and being forced to play 16:9 or 4:3 in some games is still a treat because the black bars are completely black. I just pull the monitor closer in games that don't support 21:9 and feel like I'm back on a native 16:9 or 4:3 monitor.
As far as early adopter issues, I will say that the fan noise is noticeable when in a quiet room. I've read that it's a fan for the gsync module and it seems to always be running for me. I hope they figure out how to make it passive cooled in the future.
Alienware 34 QD-OLED UFO Test
Re: Alienware 34 QD-OLED UFO Test
It's best to wait until you feel it has no deal-breakers for you (or at least not too many).jnashville wrote: ↑28 Mar 2022, 03:21So its best to wait for other companies to come onto the bandwagon for more better optimisations, features and maybe lower price points?
Assuming OLED continues to gain traction in the gaming monitor market, there will be iterative improvements, more variety in panel size/type, and, ultimately, lower price points.
I believe the fan is primarily there to allow for increased sustained peak HDR brightness, avoid obvious ABL (auto brightness limiting), and help prevent temporary image retention. The cooler an OLED panel stays, the more they can push brightness output, while avoiding negative effects.
The few HDR-capable LCD gaming monitors available also have fans (HDR brightness levels can generate a lot of heat).
Just curious, so far I have yet to seen anyone run input lag test with the native resolution. Wondering if anyone else has found one yet.
Anyone else with the panel able to force 2560x1440p resolution? Seems like it runs 3440x1440p as "Active Signal Resolution"
Does anyone know whether there is a downside to using this monitor with a Radeon 6900 XT?
I need to upgrade my GPU for this monitor and it seems that this GPU offers the best price/performance at the moment for this kind of resolution.
Does this monitor running Freesync have more input lag than running it with G-Sync?
It should work according to RTINGS - am I overlooking anything?
FreeSync and "G-SYNC Compatible" is identical at the signal layer, as they are both the respective AMD/NVIDIA certifications of generic VESA Adaptive-Sync. So I would presume no difference.
Thanks for your reply. Does this also work 100% the other way round?Chief Blur Buster wrote: ↑23 Jun 2022, 16:28FreeSync and "G-SYNC Compatible" is identical at the signal layer, as they are both the respective AMD/NVIDIA certifications of generic VESA Adaptive-Sync. So I would presume no difference.
In this case we have gsync native and freesync compatible.
This person confirmed hdr+fs works, but do the low latency features etc. of fs premium pro also work?
Today, things have changed somewhat...jani80k wrote: ↑25 Jun 2022, 05:00Thanks for your reply. Does this also work 100% the other way round?Chief Blur Buster wrote: ↑23 Jun 2022, 16:28FreeSync and "G-SYNC Compatible" is identical at the signal layer, as they are both the respective AMD/NVIDIA certifications of generic VESA Adaptive-Sync. So I would presume no difference.
The premium features of G-SYNC and FreeSync are often specific to each vendor. Past G-SYNC native monitors could never work with FreeSync, but this is no longer true -- G-SYNC native chipped monitors of certain new monitor models now work with FreeSync on AMD cards...
G-SYNC native used to be fully incompatible with AMD cards, but this kind of changed in newer models of monitors with newer GPUs -- where several G-SYNC native models works in FreeSync compatible mode that works with AMD. So it's not as simple as it used to be to explain G-SYNC and FreeSync cross-compatibility. They are now more compatible with each other than they used to be, but not universally.
It's best when the monitor manufacturer sends the monitor to both NVIDIA and AMD to get certified by both, then you're assured of performance both ways -- premium G-SYNC and premium FreeSync in the same model is now possible if the monitor manufacturer pays both NVIDIA and AMD for all that extra work. However, this is not available in all models (Premium FreeSync may be some less-good G-SYNC Compatible mode, and one of the better G-SYNC / G-SYNC Ultimate certifications may provide some less-good FreeSync mode).
So it's a "depends on the model" thing nowadays. Look closely at the spec sheet and verify compatibility -- it may be bidirectional premium compatibility, or it might be premium/ultimate/enhanced only on one or other.
