Blur Busters Forums
VLC 3.0 works with HFR
Discussion about 120fps HFR as well as future Ultra HFR (240fps, 480fps and 1000fps) playing back in real time on high refresh rate displays. Bleeding edge experimentation.
Postby Chief Blur Buster » 11 Feb 2018, 23:14
Hello,
Just wanted to confirm the brand new VLC 3.0 does indeed work with HFR video files (120fps tested so far).
Cheers,
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Re: VLC 3.0 works with HFR
Postby lexlazootin » 12 Feb 2018, 11:10
120fps works for me, although it still don't work with G-Sync fullscreen :x ill probably test with 240fps for fun tomorrow
lexlazootin
Postby RealNC » 12 Feb 2018, 11:55
Try different back-ends. OpenGL should work with G-Sync. However, whether it's useful or not depends on whether you can disable the triple-buffer-like behavior that many video players use (draw the same frame repeatedly.) In mpv this is called "display sync". VLC could be using something similar.
(This is used to minimize frame skips due to missing a vblank.)
Postby Chief Blur Buster » 12 Feb 2018, 12:11
Video players definitely do need to be VRR compatible to allow it to play any framerates.
Indeed, there's no such thing as a "missed vblank" when running with variable refresh rate -- the display simply waits for your software's frame instead.
Postby nuninho1980 » 12 Feb 2018, 17:40
I tested new "Direct3D11" using VLC 3.0 final but... I got not always 50fps (= stutters randomly) at 50Hz. FAIL! :S I got no any stutters at Direct3D using VLC v1.1.9 and v2.2.6.
My PC specs:
CPU: Core i7-4790K
RAM: 2x8GB DDR3@2400MHz
MB: ASUS Z97-Pro Gamer
GPU: EVGA GTX 980 Ti SC+ :D
HDs: WD 1TB + new SSD OCZ RD400 512GB + 2TB ext-USB
PSU: NOX 1 kW
Monitor: CRT 19" Samsung SM 957MB :D
nuninho1980
Postby Chief Blur Buster » 12 Feb 2018, 18:03
Hmmm!
You (we) should report this bug.
Return to High Frame Rate Video (HFR)
Who is online
Users browsing this forum: No registered users and 1 guest
