Hello! First time poster here and I guess this a question for the software developer of desktopbfi or another software black frame insertion software….
I have been trying out the DesktopBFI software, which has worked great for 60hz on my LG b7a
I was wondering if it’s possible to change the interval to get an effective 48hz or 72hz from the 120hz signal with the software?
I was able to do this with my Plasma as it interprets 24fps content at 48hz and it pulses the images, but I would love to do something similar with my OLED even though it doesn’t have hardware BFI.
Basically I really like watching 24fps content at 48hz or 72hz with BFI because it reminds me more of what I see at the cinema.
If anyone can help me with this, I’d really appreciate it and I’m hoping some other people will find it useful too. Thanks!
LG B7 and Desktop BFI
Re: LG B7 and Desktop BFI
Hey,
Have you tried Special K's new black frame insertion feature? That's a new one that just came out. It only functions during games rather than the WIndows desktop.
As for 72Hz, you need to create a custom 144Hz mode. Does your LG support 144Hz?
As for 48Hz, you need to create a custom 96Hz mode. Does your LG support 96Hz?
(probably not)
(probably not)
Hello and thank you for your response! Also I apologize as I definitely posted this in the wrong category...
I have used special K before, but not for this application. Although I didn't mention this in my initial post, I would like to use it when watching movies.
I'm pretty sure by LG B7A only does 120hz although I would be happy to be wrong.
Is there a way to have something like DesktopBFI black out something other than half the frames on a 120hz only monitor (like for 48fps more black frames or for 72hz less black frames) ?
Chief Blur Buster wrote: ↑08 Dec 2021, 18:28Hey,
(probably not)
120 is not divisible by 48 or 72.
However, 120 is divisible by 5 so you could do 1:4, 2:3, 3:2 or 4:1 black frame insertion with 24fps cinema material but it would flicker very badly, like 48Hz. You could use 144Hz to double-strobe 48Hz in a cadence of 1:2:1:2 or 2:1:2:1 ON:OFF:ON:OFF
Unfortunately, neither DesktopBFI nor SpecialK supports this.
