blurry appear when paly long time pubg with XG2431 VRR 120hz
All newer XBOX consoles supports 120Hz+ & FreeSync. Getting help with getting "Better Than 60Hz" on the XBOX ONE, XBOX Series S, and XBOX Series X, as well as the PlayStation 5.
jin
Post by jin » 12 Jun 2024, 21:30
Hi folks,
I'm enjoy play PUBG with the XG2431 VRR 120hz on XBOX Series X.
but sometimes it appear blurry(can't aiming to the other player correctly) if i play long time or didn't clear the remaining power when i starting play.
So.. I always unplug the power cable then remove the remaining power with power button then plug power cable everyday before i play..
After doing that, my monitor shows clearly.
Is there someone with same issue? i love XG2431, but only this one is issue for me..
