Blur Busters Forums
Using Acer GN246HL with Xbox One S
The XBOX ONE Console supports 120Hz+, FreeSync, and 1440p. Getting help with getting "Better Than 60Hz" on the XBOX ONE.
Postby aelzufon » 16 Jul 2018, 16:45
I just got an Acer GN246HL and want to know the best settings/setup to use with my Xbox One S.
I don’t really know a whole lot about this so just looking for some help with enabling light boost and any other settings.
Thanks for the help!
aelzufon
Re: Using Acer GN246HL with Xbox One S
Postby Chief Blur Buster » 26 Jul 2018, 02:06
You cannot enable LightBoost with the XBox One. It is DRM-locked to NVIDIA products and can only be enabled when connected to a PC GPU.
You need a different brand-name strobe backlight technology that is video-card-independent if you want to use blur reduction with the XBox one.
That said, you may still be able to use 120Hz (non-VRR, non-strobed) -- though it will take time before many XB1 games fully enable the 120Hz support.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Postby RealNC » 24 Oct 2018, 07:04
jasonbernat wrote:I'm trying to connect my Xbox One to my ASUS VG27AH monitor. The Xbox and monitor are connected directly by HDMI but my monitor is telling me there's no signal. I expect I'm overlooking something simple here, so any help would be appreciated. Thanks!
Try switching the monitor to HDMI manually. Maybe the autodetection is disabled.
Return to XBOX ONE Console
Who is online
Users browsing this forum: No registered users and 1 guest
