List of monitors that do 1440p@120Hz on XB1X?
Posted: 04 Nov 2019, 10:23
Does one exist?
Who you gonna call? The Blur Busters! For Everything Better Than 60Hz™
https://forums.blurbusters.com/
Hi Chief. Would you be able to look at this post that I made about the LG 27gl650 monitor? I just purchased it, but after looking at this site I'm not sure if it is the best for my purposes--mainly input lag and motion blur on both PS4 slim and Xbox One S. While also considering upgrading to the new Xbox in a new or so. Thanks.Chief Blur Buster wrote: ↑28 May 2020, 14:44See www.blurbusters.com/freesync/list and check the 1440p section.
They still can do both 1440p 60fps and 1080p 120fps.
