Xbox Series X - 1440p 120hz would be optimal for FPS games, correct?
Posted: 13 Mar 2022, 11:09
I have an XB Series X. I play FPS games at 120fps. It seems most games output to 1440p. Unlike a PC, you cannot lower the resolutions. So am I correct in thinking that a 1080p gives no advantages, like it would on PC with higher and more stable frames?
Since games like Halo Infinite and Fortnite are outputting 120fps at 1440p, no matter your monitors native resolution, am I better off just getting a 1440p monitor?
Also, anyone have any recommendations for a 1440p monitor with low input lag at 120hz? Seems most the input lag numbers are at 240hz or whatever the native frames are (usually 165+). I see that usually the higher refresh monitors (240+) usually have pretty bad 60hz performance. So I would assume the best monitors for 1440p/120hz would be 144hz models.
I also read on here that because Xbox forces Vsync, you actually get lower input lag when using VRR on the Xbox.
I am stuck between getting these monitors right now:
MSI Optix MAG274QRF-QD
BenQ Mobiuz EX2780Q
BenQ Mobiuz EX2710Q
Gigabyte M27Q
BenQ Mobiuz EX2780Q
BenQ Mobiuz EX2710Q
Gigabyte M27Q
