Can someone make a HumanBenchmark test
- lexlazootin
Can someone make a fullscreen non-vsync app that I can run to test my reaction time, possibly configurable colors and settings.
Or is there a reliable one out there already made? I don't really like the one on the website because i'm using windows 8.1 with aero and also because it's in a web browser.
Re: Can someone make a HumanBenchmark test
you can throw together one with love2d pretty easily
- lexlazootin
Never really coded before and this looks easy enough... just going to copy and paste from everyone else projects till it works, normally what I do when I need to code.
- lexlazootin
I think I did it. I get much better times then I ever did on humanbenchmark but it might be because my code doesn't work.
Edit: http://pastebin.com/m7uKfGWh fix2
math.random only needs a min and a max...
i think on the website the time when the color changes is a random num between 2 and 5 or somethign like that
also you should use fraps or something to make sure it's not running with vsync
- lexlazootin
flood wrote:math.random only needs a min and a max...
Whyyyy, I had vsync off and then when I turned it back on for testing it now no longer turns back off... why would you do this too me..
- lexlazootin
I have AMD and for some reason when forcing it off in the driver I have to run the love.exe then run the batch file or the change wont be made
Also using the ingame FPS counter seams to work fine for telling if vsync is off for every combination I tried using fraps. I don't know if you had problems or something.
And I just assumed that math.random() would pick one only one of the numbers I gave it and not a random decimal in between.
Thanks Btw, i'm very happy with the end result.
Nice program, thanks.
I'm getting around 50ms better results with this than with humanbenchmark.com, both @120hz.
For v sync off change line #2 from to
Also i would change state 1 to black and state 2 to green because right now it's confusing.
Code: Select all
love.window.setMode(0, 0, {fullscreen = true})
Code: Select all
love.window.setMode(0, 0, {vsync=false, fullscreen = true})
