Using a reshade black frame insertion shader fx?
Talk to software developers and aspiring geeks. Programming tips. Improve motion fluidity. Reduce input lag. Come Present() yourself!
deama
Re: Using a reshade black frame insertion shader fx?
Post by deama » 24 Aug 2019, 10:06
Kheri wrote:Well, I haven't much luck with the program yet -- it just flickers like mad.
I did something like this to get it working on the primary display:
https://docs.microsoft.com/en-us/window ... terfromhdc
Code: Select all
	DISPLAY_DEVICE dd;
	memset(&dd, 0, sizeof(dd));
	dd.cb = sizeof dd;
	int i;
	for (i = 0; EnumDisplayDevicesA(NULL, i, &dd, 0); ++i) {
		if (dd.StateFlags & DISPLAY_DEVICE_PRIMARY_DEVICE) {
			break;
	oa.hDc = CreateDC(NULL, dd.DeviceName, NULL, NULL);
What are you supposed to do with that code?
Kheri
Post by Kheri » 24 Aug 2019, 16:59
deama wrote: What are you supposed to do with that code?
That's just a code snippet I put into my own copy of the source code to get the program detecting my primary monitor; I have a multi-monitor setup. I didn't feel like putting it up on GitHub. I'm also not sure how good/appropriate of a solution it is.. I believe there are other ways to get the Device Context or Monitor ID. All of that code snippet replaces the single "oa.hDc = ..." line in the source code. (Then you would have to "Build" it into an executable, of course.) Hope that makes sense.
Edit: to be clear, the snippet is just for detecting the main monitor. I couldn't successfully run the previous executable because it was failing to do so. It doesn't prevent the monitor from flickering.
deama
Post by deama » 24 Aug 2019, 23:16
Oh ok, I only got 1 monitor.
fuzun
Post by fuzun » 30 Aug 2019, 19:55
squeaksci wrote:I got it to work! It's a tiny C++ program, if you want to compile it, it uses the Windows Driver Kit for a v-sync function.
Github page: https://github.com/squeaksci/desktopbfi
Download, if you're comfortable running a program from a stranger: https://github.com/squeaksci/desktopbfi/releases
Problems are likely, I'm not a great programmer. Let me know how it goes!
I think that this project is really interesting. This was something that I wanted to do in my free time.
I have tested it and in my computer it works quite good.
If you are interested, I have integrated my small and not very well coded "strobe" library into this project.
With it, this is now much more flexible. If you have 144hz monitor, now you can try [RENDER - BLACK - BLACK] sequence instead of classic [RENDER - BLACK] as R-B causes some color problems.
I suggest Render Mode: 2 or -2 for 144hz monitor. Note that even modes have advantages because they don't require algorithms to prevent image retention.
Source Code:
https://github.com/fuzun/desktopbfi
Binary:
https://github.com/fuzun/desktopbfi/releases/tag/v1.1
Usage:
desktopBFI.exe [Strobe Mode] [Phase Switch Interval in Seconds] [Debug Mode]
if you set debug mode = 1, this will show up:
deama
Post by deama » 01 Sep 2019, 03:11
Source Code:
Binary:
Usage:
I tried it and I still get lots of flickering, what's going on? Is it something to do with my monitor or computer?
Here's a picture of the debug, it seems like it can't really reach 144fps? I tried setting the priority of the program to high but didn't really make a difference.
EDIT: Hmm, ok, maybe not, I tried again with a -2 render mode this time and the fps was higher, but there was still a bunch of flickering:
Post by Chief Blur Buster » 04 Sep 2019, 23:19
One could also temporarily switch to the Performance plan temporarily while running this BFI module.
This can also be done programmatically (using API to switch to high performance mode) via the PowerGetActiveScheme() and PowerSetActiveScheme() to force the computer to 100% GPU. At least you'd notify the user of reduced accuracy if you're on the battery-miser power plan...
This will kill battery, but can dramatically increases BFI precision.
Also, you may have to also reconfigure the GPU separately in the GPU's control panel to disable GPU power management.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
EDIIIZ
Post by EDIIIZ » 17 Sep 2019, 17:02
squeaksci wrote:Alright, I updated with Chief's polling suggestion, it fixed the flickering on my other computer, though I couldn't test any games on it. I hope it works! Same download link: https://github.com/squeaksci/desktopbfi/releases
Hey, just tried your programm with my already strobed display and the "motion blur" and "overdrive artifact" results are amazing. Ofcourse brightness and fluidity is trash.
I have the LG 24GL600F with a 144hz refresh.
The HW Blur reduction has alot of Strobe Crosstalk.
Your Software BFI has none but clarity isnt as good. Now when i combine Software BFI with Hardware BFI Clarity is perfect, Overdrive Artifacts are gone and Strobe Crosstalk is also gone. Can someone explain this? :D
Double Strobed (Software + Hardware + Highest Overdrive)
Single Strobed (Hardware + Highest Overdrive)
Post by Chief Blur Buster » 19 Sep 2019, 15:34
EDIIIZ wrote:Your Software BFI has none but clarity isnt as good. Now when i combine Software BFI with Hardware BFI Clarity is perfect, Overdrive Artifacts are gone and Strobe Crosstalk is also gone. Can someone explain this? :D
Combining hardware and software strobing can be useful:
(1) The hardware strobing ensures that you've got sub-refresh persistence. (Software-only can only adjust persistence in refresh cycle increments).
(2) The software strobing can add a humongous emulated VBI between hardware-strobed refresh cycles. The black frames helps erase the previous frame quicker, allowing much cleaner GtG pixel response to a new refresh cycle.
Essentially, your software BFI is simply a 120Hz-to-60Hz hardware strobe converter. Your software BFI blocks every other hardware strobe
(3) It makes possible single-strobed 60Hz out of 120Hz hardware strobe backlights that have an arbitrary manufacturer firmware limitation against 60Hz single strobing (this is a design decision made by most manufacturers, due to not wanting to give 60Hz flicker for users).
Hardware BFI to generate 120Hz strobed, and software BFI to block every other strobe, to create 60Hz hardware strobed on a monitor that doesn't have hardware 60Hz strobing support.
This can be poor quality on some panels and higher quality on other panels (OLED and IPS LCD is very friendly to the hardware+software BFI combination).
