It is the body that causes issues
Re: It is the body that causes issues
I believe this issue is either an MKUltra like experiment or we are experiencing a phenomenom that is yet to be discovered
It is so ridiculously easy to verify:
1. Buy wireless mouse.
2. Buy wireless keyboard.
3. Buy huge desk.
4. Play from the furthest possible distance from your PC.
5. Share your thoughts.
3. Buy huge desk.
Then you could say your body affects mouse or keyboard internals. I guess it would have optical chipset to avoid this.cursed-gamer wrote: ↑16 Feb 2024, 14:57It is so ridiculously easy to verify:
3. Buy huge desk.
Ryzen 7950X3D / MSI GeForce RTX 4090 Gaming X Trio / ASUS TUF GAMING X670E-PLUS / 2x16GB DDR5@6000 G.Skill Trident Z5 RGB / ASUS ROG SWIFT PG279QM / Logitech G PRO X SUPERLIGHT / SkyPAD Glass 3.0 / Wooting 60HE / DT 700 PRO X || EMI Input lag issue survivor
Then cover a mouse with lead foil and buy analog keyboard.dervu wrote: ↑16 Feb 2024, 16:45Then you could say your body affects mouse or keyboard internals. I guess it would have optical chipset to avoid this.cursed-gamer wrote: ↑16 Feb 2024, 14:57It is so ridiculously easy to verify:
3. Buy huge desk.
already tried with 10m cables (mouse, keyboard and monitor), same thingcursed-gamer wrote: ↑16 Feb 2024, 14:57It is so ridiculously easy to verify:
3. Buy huge desk.
already tried antistatic gloves and foil, same thing
An earthing mat matches your body's voltage to that of the Earth's*. Voltage is a potential difference. Depends on where you live, earth potential is not always lower than Mains Neutral. Which in my case it's not, we actually have an elevated earth potential where I live, which is about 1.5-2V more than that of the Neutral. In my case, It can be a combination of electronic appliances used by the neighborhood, a really close by ground transformer and a rocky ground in general.Lagsadok wrote: ↑14 Feb 2024, 20:5330 minutes ago I tried playing with my PC outside it felt perfect except it started overheating cause it was in the direct sunlight lol. Played about 15 minutes of deathmatch and it felt perfect the whole time. If anyone else is in a position they can try it to test please do, obviously if you're in an apartment it probably isn't possible. I will try a grounding or earthing mat as I saw it lowers the bodies voltage to 0.
Anyways, Please don't do this if you have a conductive case style wired keyboard, I.E Aluminum. Unless you have wireless peripherals I highly suggest that you don't do this as your PC will continuously discharge not only through it's PSU>Receptacle>Ground Bar>Earth/Neutral Bar, it will also do it through Keyboard>You>Receptacle>Ground Bar>Earth/Neutral Bar.
If your circuits are protected against earth leakage, let's say, RCBOs, RCDs etc. Then go ahead "in case of wireless peripherals", otherwise don't plug yourself into an unknown unprotected circuit, it's extremely dangerous.
Rog Strix Z790i - Intel 13700K - 4090 OC ROG Strix - 7200 Trident G.Skill - 1TB SK Hynix Platinum P41 - 1000W ATX3.0 Asus Tuf - 34'' Odyssey OLED G8 - FinalMouse Tenz S/Pulsar Xlite V2 Mini - Wooting 60HE - Sennheiser HD 560s - Shure SM7b - GoXLR Mini
i can confirm after 10 years active fixing spending money, time. changing houses with new setups all new, its body causing this issue
I can confirm, that wherever I play, it's the same everywhere. I mean it's never been noticeably better or worse than previous place, doesn't matter what.
and i can say the biggest impact on my input lag problem its after i started going to gym, everytime when i come back from gym its everything perfect for few minutes - 1 hour. I know it's inexplicable but its true. my input lag can be bad 99% for day but when i go to gym and comeback everytime perfect.
I don't know if it's a coincidence or not, but I would agree that it's my body that does it. When I lived with my parents, there were always problems with the electricity in the house. I have even lost 2 computers because of thunderstorms. When I lived with my parents, there were always fuses blowing, power outages and so on. It seemed that when I was at home, there was always some kind of overload. When I went to live separately, there were no problems with the electricity in my parents' house. When I moved to a new apartment, after a while the electricity problems started again. I remember that the electricians were working on the problem for a whole week, and there was even a huge generator behind the house. The neighbours told me that for a long time there were no problems with the electricity until now. I have looked on the internet and found that there are indeed people who make electrical equipment work poorly.
