emi
Re: emi
did you have grounded outlets in your home?
Re: emi
Ok i have a tip for you cut the ground…
Buy cheap spliter outlet and cut the ground wire its not that technical so you should be able to do this it will cost you 5euro…
Then test you PC without the ground.
You need to connect first PC, monitor and router nothing else… If you see kinda improvement then yeah maybe will PC full recover maybe not it need to be tested.
Issues like yours 100% as mine cut the ground and we go from there
- DF4B35E0-A77B-4B2E-970A-904B84ACDCE2.jpeg (4.02 MiB) Viewed 2341 times
- 75094201-7D31-44F3-9B5D-3259B316CE78.jpeg (2.72 MiB) Viewed 2341 times
Re: emi
You can see that on second picture is not LED light Ground OK. That means the ground is not connected and the PC work way better then with the ground just by this proces. I am ordering new mobo in case that the older one is allredy broken it may be….
Re: emi
Does it feels like the input lag issue is totally fixed or does it feel like there is still room for improvement? Also, for how long have you been using your PC without grounding?
Re: emi
For sure there is room for improvement but if the issue is realy what i think the components may be damaged permanently so… they may prerform well if at least mobo is changed. i am realy looking to change some parts
Its not looking like time limited fix
Re: emi
i realy recomend it keep it this way monitor, pc, without ground and if you have old mouse or diferent mouse give it a try
Re: emi
Yes, for the time being I will continue to use my PC without grounding and try to find if there are any differences compared to running PC with grounding.MegaMelmek wrote: ↑28 Jun 2022, 13:22i realy recomend it keep it this way monitor, pc, without ground and if you have old mouse or diferent mouse give it a try
Also, could you share your outlet grounding values (the outlet you use for PC/plug your extension cord to), measured through AVO?
