You have a link of one power station in particular ?pox02 wrote: β28 Jun 2022, 05:02hes power station build internally i never will go on that path if i was him external is much betterwadge wrote: β27 Jun 2022, 15:32Thats something i had i mind but i saw a post from a guy on this forum who said power station didn't help... and it's not cheap, it's around 1000β¬ for a good onepox02 wrote: β27 Jun 2022, 12:31u are correct most psus sensitive to 230v/50hz because most of them build on 120v/60hzwadge wrote: β27 Jun 2022, 11:23Or is it possible to use a converter like this one : https://www.amazon.co.uk/dp/B07BG983Y5? ... th=1&psc=1 to convert 220v to 110v and then use something to regulate the frequency like a VFD : https://www.amazon.co.uk/Fictory-Motor- ... NrPXRydWU= not sure how to wire the vfd as it is single phase to 3 phase
I also ordered a small device to check the frequency that comes to my wall outlet to see if there is a significant variation or not.
From what i read online, old hardware might have been sensitive to ac frequency but maybe modern hardware with crystal clock aren't...
To me it must be something going out of sync/clock as the first game of the day is always on point (i mean when i start the pc and it was shut down for a while) and then it deterior...
good video why 50hz worse on europe
i suggest get power station with external batteries u get best of both worlds 120v/60hz + able to charge the batteries with 230v/50hz u can look at " ego power station"
PC- is affected with 230V -TEST
Re: PC- is affected with 230V -TEST
wadge wrote: β28 Jun 2022, 08:29You have a link of one power station in particular ?pox02 wrote: β28 Jun 2022, 05:02hes power station build internally i never will go on that path if i was him external is much betterwadge wrote: β27 Jun 2022, 15:32Thats something i had i mind but i saw a post from a guy on this forum who said power station didn't help... and it's not cheap, it's around 1000β¬ for a good onepox02 wrote: β27 Jun 2022, 12:31
EGO Power+ PST3040 google ch5500e charger try to found on your location 12ah/10ah batteries cause impossible to ship them IATA law BA6720T/BA5600T
Well ok; i read not so good review about it regarding the autonomy...
What is your theory behind that : ?
Windows actually accounts for offsets in frequency automatically. If you want to learn more I suggest reading thiswadge wrote: β27 Jun 2022, 16:05Thats also true but i'm convince something is altering the way our pc is supposed to work properlyThatweirdinputlag wrote: β27 Jun 2022, 15:40Didn't even realize how much AC power can effect a game. 20% slower is actually insane! Then again, any sort of power passing after the PSU is purely DC "Direct Current" in the form of 3.3V, 5V and 12V. Those go through separate rails and do not have a frequency like Alternating Current, their frequency is actually 0 since the current is always on at any given time. All monitors also have power supplies that also transforms the AC into DC.
Just as a side note, a lot of the top tier teams in the ESports industry specially in triple A titles are EU teams, and I can guarantee you on that high level of skill and competitiveness, they wouldn't have been able to make it by being 20% slower.
And therefore i also came on a different supposition, at the end what rules our pc are those clocks build in it called crystal oscillators. I found an interesting article about temperature affecting the way they are working and there is other culprit (voltages, rfi and so on)
here is the link : https://www.electronicdesign.com/techno ... n-crystals
I'm sure we can all regroup our knowledge and finally find what is causing all this mess !
https://docs.microsoft.com/en-us/window ... ime-stamps
Sometimes it's the PSU's fault in producing more EMI with a certain voltage (120V versus 240V or vice-versa).
Cheap chinese power supplies are more problematic than high-end brand-name power supplies. Typically this is not always fixable via an external power station (e.g. lithium batteries).
Please be noted that PSU-based interference is extremely hard to diagnose. Even switching voltages isn't guaranteed.
This was more of a problem back in the analog days when you were stuck with 50Hz or 60Hz considerations. Consoles could only do one refresh rate back in those days -- and VSYNC ON during PAL runniing at 50fps vs 60fps would not affect a normal computer GPU which can run refresh rates decoupled from the mains frequency.
It's a useful datapoint to explain Europe vs US problem, but doesn't explain the OP's problem.
Just one caveat, the video doesn't explain the OP's problem.pox02 wrote: β27 Jun 2022, 12:31u are correct most psus sensitive to 230v/50hz because most of them build on 120v/60hz
Forum Rules wrote:ββ1. Rule #1: Be Nice. This is published forum rule #1. Even To Newbies & People You Disagree With!
ββ2. Please report rule violations If you see a post that violates forum rules, then report the post.
ββ3. ALWAYS respect indie testers here. See how indies are bootstrapping Blur Busters research!
