Using off-grid tips
Posted: 09 Nov 2024, 12:59
by akylen
Hello, I am a novice in terms of everything related to electricity, which is why I am asking my question here in order to have a little more visibility for my questions.
My question is: does this kit >
https://kitsolaire-discount.com/fr/kits ... ombination
Could support my needs regarding only my gaming PC with say 12+ hours per day on it.
For information, I am in the geographical area with the attached image.
The power supply is as follows > Corsair RM1000e (2023)
Thanks.
Re: Using off-grid tips
Posted: 11 Nov 2024, 21:47
by delve
Don't do it, get a lithium power station instead that you can charge from the wall and return easily, if you want to test offgrid.
- solar only works 6 months a year
- who is going to install it safely and properly, not you
- lead acid batteries are trash
- likely not refundable
- solar off grid has been tested without success a bunch of times
Posted: 12 Nov 2024, 00:07
by Slender
delve wrote:
11 Nov 2024, 21:47
it is like big power bank?
It can work with a 500W PC/monitor for so long?
Can charging this power bank from the bad elec. back the problem?
Posted: 12 Nov 2024, 01:19
by delve
you have to figure out the real power consumption of your pc, cpu + gpu TPD is a good rough measure plus the monitor of course. To power a 500W setup for an hour you would need a 600Wh power station for example.
Posted: 12 Nov 2024, 04:37
by spkii
Someone tried with this?
https://www.amazon.es/FOSSiBOT-F3600-Ge ... 84ed9b0efd
12 hours off grid, charged in 2 hours.
Posted: 08 Dec 2024, 09:09
by 1nputlag
Hi akylen i saw you are french add me on discord: 0jsr
Posted: 09 Dec 2024, 10:40
by iizana
1nputlag wrote:
08 Dec 2024, 09:09
can u accept my friend request ? im french too
my discord : ryuukooo___
