Is anyone else here also considering going with the solar route? I mean it is pretty expensive and gimmicky to do but there are ways to make it cheaper and it is not as hard to set up as I thought it would be
- For example you can build a power effiecent rig that only uses 180w and runs games amazing for 500€. I already posted it here it is DeskMini x300 & Ryzen 5 3400g
- X2 150w Solar Panels are 100€ each and provide more than enough power for this set up
- Power Controller 25€
- 12v 100Ah Battery is around 120€
- 12v DC to AC power Inverter is 30€ but everyone suggests UPS or Inverter with Pure Sine Wave to protect components but it is much more expensive
So overall it costs 890€ or just 390€ if you already have a laptop to have 3-4 hours of juicy smooth gaming
Ok i think might figured out seem but said countless times but give shot seem EMI coming from monitor i using alienware AW2721D 240hz HDR but did same prior gsync monnitor. Out of countless things i bought including countless new PC parts, I got one of those $150 heavy shiwlded PSU cable from bestbuy for my PC. It seem to help but not all time.
So today bored i tucked my displayport cable under my PC and noticably better but seem to slowly creep back. I got idea take high end power cable from PC and use it on monitor and its working so. consistently stable no charge buildup.
So yea seem like more power PC consumes more floaty mouse gets. Even cell phone changers unplug them from wall even if in another room. also I had t go into my mom ipad turn off all facebook BS that counstiantly connecting online even that helped.
So yea try better power cable for monitor https://www.bestbuy.com/site/audioquest ... Id=6265862 plug into monitor and see what up. You can return it if doesnt work. Ill give update tomorrow.
So today bored i tucked my displayport cable under my PC and noticably better but seem to slowly creep back. Seemed like PC was blocking EMI. I got idea take high end power cable from PC and use it on monitor and its working so far. consistently stable no charge buildup.
So yea try better power cable for monitor plug into monitor and see what up. You can return it if doesnt work. Ill give update tomorrow.https://www.bestbuy.com/site/audioquest ... Id=6265862
Also what i said also about 8k viper high recomend if you play at high refresh make even smoother awseom and think working better becasue thicker better shielding cable.
Why not use a portable generator running on a gasoline? It is much cheaper.
yes, i asked my elec. provider to change transformer for brand new, after 2 days they come to change it, but still the same.
https://www.youtube.com/watch?v=zsA0KkbDaGA
even in my video you can hear buzzing sound, my phone picked EMF or something in my area
Maybe make a list of what worked and what was useless? for example
1. moving to another location - max effectively
2. solar panels - helped someone
3. electrolytic grounding - helped someone
And what does not help at all or for a short time UPS, filters, etc
And what not tested - toroidal transformer, faraday cage ...
I agree saw few comments about buzzing noise and stuff with regular inverter and stuff so better to go with pure sine wave inverter
