[Troubleshooting Equipment] ways to mitigate interference
nick4567
Post by nick4567 » 21 Sep 2021, 14:48
firstly if u want to not be under just speculating and actually want to know if ur alleviation solutions are doing anything other than placebo u will need to by some testing tools these tools are relatively cheap some are even very easy to use ,
emf meter www.amazon.com/dp/B07JGJ897T
picoscop oscope www.picotech.com/oscilloscope/2000/picoscope-2000-specifications
ammeter clamps www.grainger.com/product/20E890
ammeter probes www.picotech.com/accessories/bnc-current-probes/600-a-current-probe-bnc
these are the testing devices you will need
none of these will confirm bit error rate increases but they will confirm the presence of interference
mitigation techniques certain areas within ur home might have lower fields u will find that out with the gq emf tool
some interference maybe strictly inducted/conducted in which case ferrites/toroids will help alleviate the issue
do not buy the snakeoil that is audiophile marketed devices they are low cost devices that do basically nothing
good luck
[Moderator Edit -- Vetted and tidied up links]
naporitan
Re: [Troubleshooting Equipment] ways to mitigate interference
Post by naporitan » 22 Sep 2021, 11:51
all this stuff is useless, you need a harmonic distortion meter.
nick4567
Post by nick4567 » 22 Sep 2021, 12:18
naporitan wrote: ↑
22 Sep 2021, 11:51
The oscope measures harmonic distortion and if u have ammeter probes u can find out if its current harmonic distortion or voltage harmonic distortion tldr not useless
Eonds
Post by Eonds » 23 Sep 2021, 19:14
naporitan wrote: ↑
22 Sep 2021, 11:51
If you have a properly shielded computer case and you're experiencing issues the interference is probably local.
Try these in your bios:
Pcie Pll SSC - 2.0%
PCIe Spread Spectrum Clocking - Enabled
FIVR spread spectrum - Enabled
VRM spread spectrum - Enabled
RFI Spread Spectrum - 6%
bus clock spread spectrum (SB spread spectrum) - Enabled (-0.475%)
SRIS (separate reference independent spread) - Enabled
nick4567
Post by nick4567 » 23 Sep 2021, 20:27
Eonds wrote: ↑
23 Sep 2021, 19:14
naporitan wrote: ↑
22 Sep 2021, 11:51
Pcie Pll SSC - 2.0%
everyone who has a mobo that can do this has tried this not only that but lots of people have had their motherboards bricked because someone in here recommended to flash a custom bios
naporitan
Post by naporitan » 24 Sep 2021, 04:08
Pcie Pll SSC - 2.0%
You must understand that the problem comes from electricity, not external influences.
Eonds
Post by Eonds » 24 Sep 2021, 10:13
naporitan wrote: ↑
24 Sep 2021, 04:08
Pcie Pll SSC - 2.0%
You don't know that. You're taking a wild guess. You might as well try it before making bold claims like that
Eonds
Post by Eonds » 24 Sep 2021, 10:15
nick4567 wrote: ↑
23 Sep 2021, 20:27
Eonds wrote: ↑
23 Sep 2021, 19:14
naporitan wrote: ↑
22 Sep 2021, 11:51
Pcie Pll SSC - 2.0%
No actually they haven't tried these because most of these aren't accessible through stock bios unless you use scewin & or custom bios & flashing a custom bios is fine if you know what you're doing.
naporitan
Post by naporitan » 24 Sep 2021, 14:10
You have the option of solving this problem by contacting an electrical laboratory and if they find a high level of harmonic distortion, then the electricity supplier is obligated to correct this. For example, I am from Russla and we have 11 power quality parameters and they are observed by a standard called "GOST" translated as state standard.
  • 11 power quality parameters from the Russlan standard:
steady-state voltage deviation;
voltage variation range;
flicker dose;
voltage curve sinusoidal distortion coefficient;
coefficient of the nth harmonic component of voltage; this problem causes input lag
coefficient of voltage asymmetry in reverse sequence;
coefficient of unbalance of voltages in the zero sequence;
frequency deviation;
voltage dip duration;
impulse voltage;
temporary overvoltage coefficient.
agendarsky
Post by agendarsky » 24 Sep 2021, 14:35
naporitan wrote: ↑
24 Sep 2021, 14:10
flicker dose;
impulse voltage;
Im not denying anything you said but why is issue present on ups battery without ups plugged to ac.
