I dont have a phone that can record over 120fps and even if i have, im not going to record to prove to you that i have lag, either believe what im saying or piss of
tried 3 locations in 1 year, lag isnt gone
Re: tried 3 locations in 1 year, lag isnt gone
How do you even know, if have alot of lag then? You moved 3 times, and you didnt test it once? Btw, why do you respond so weird? Like, you are really toxic dude... calm down.Mugabi wrote: β05 Oct 2021, 17:46I dont have a phone that can record over 120fps and even if i have, im not going to record to prove to you that i have lag, either believe what im saying or piss of
Mugabi wrote: β05 Oct 2021, 17:44Lol my monitor is xg258q, nice try thoashrr wrote: β05 Oct 2021, 17:24What monitor? I've seen some guy complaining about input lag but at the same time using a 60hz TV.Mugabi wrote: β05 Oct 2021, 12:58Pc parts are not the issue, all are new.MegaMelmek wrote: β05 Oct 2021, 09:04
well if you play cs go there is some change that will not solve the input lag and suttering but make it way more enjoyable.
There is no point to say what i have done to fix this hard input lag on new PC.
I advice you get difrent mobo and new ssd thats all you need.The last that work for me is x570 asus rog strix f-gaming and new cheap ssd. I do belive that there is input lag building in time since you turn ON some PCs.
I am still on long way because i am on 3 days working PC wich i think is not much to say its fixed but that mouse feel in W10 on this mobo its insane and its not degrading. CS go is diffrent story if i run it in real time priority, mouse is perfect if in normal priority its kinda bad nearly same as on b550. For sure there is no need change hause or mouse or monitor or CPU becaise if you benchmark your cpu and it perform well its nothing wrog with it ond so on. CS Go is more complex it need fast internet fast cpu fast memory and so on at once and there is no benchmark like that. New mobo are not capable to do that all these sheets with latency are pointless if average plyer can see that there is something wrong with shot reg mouse latency and stuttering.
The reason i want to know your harware is that i can exclude it i my testing.
Rtx 3070-5600x-b550 aorus elite ax- trident neo 16gb ram 3600mhz cl18-650w and 850w gold psus.
I suspect its my mobo m being faulty
well mate i think you should change your MOBO the b550 are wery limited to your HW. Now 4th day and mouse in CS GO is rock solid. Before most of my one taps and spray bulets was not registred and this is not happening now.
You can grab some x570 and if its not working for you just put i back in shop they will return the money back. Thats what i do. Allready tested B550 asus and MSI, b450 MSI all bad for cs go they cant operate LAN, 1000Hz usb, cpu, gpu and nvme/sata at the same time thats the limitation. Too much bandwidht at the same time couse bad issue.
I actually spoke to many ppl from reddit who apparently have similar issues and they all have the same mobo, it looks like im gona change it soon and see how it goes, if the lag returns then im gona move on with my life and never look back...MegaMelmek wrote: β06 Oct 2021, 03:39
It might not have been long enough because it took me several days until I could overclock my GPU past 1650mhz to 1750mhz after installing 3 different power conditioners and linking them up.
Well like I said, I was able to overclock my GPU from 1650 to 1750, before it would crash within 1 minute running a benchmark.
Ok but do u have these issues input lag bad hit reg slowness etcdeama wrote: β06 Oct 2021, 13:50Well like I said, I was able to overclock my GPU from 1650 to 1750, before it would crash within 1 minute running a benchmark.
