Hello!
My friend has recently bought MSI 271QRX and heexperiences some weird flicker that I have never seen before It doesn't look like classic near black OLED/LG flicker
Video attached: https://streamable.com/sjdlyk
Settings used: 360 Hz, G-Sync On, V-Sync On in control panel
Bad cable? Tried different DPs and HDMIs
Bad monitor firmware?
Flicker on 271QRX (not typical)
Re: Flicker on 271QRX (not typical)
Turn off overdrive in the monitor OSD and see if that helps. It's recommended to disable overdrive anyway with his display.
I was going by what the rtings review said, which is "Recommended Overdrive Setting: No Overdrive". I misunderstood that as a recommendation to disable overdrive. But apparently what it means is that this display has no overdrive.
Update (forgot to post)
It was nvidia framelimiter misbehaving, FPS lock didn't lock work properly and FPS/frame time fluctuated a lot causing flicker
Fixed after reinstalling drivers with DDU
As far as I'm aware most if not all OLEDs out now have no overdrive setting.
Thanks for letting us know how you fixed it. I will also try it as you did.
