RealNC wrote:Nope, it still doesn't offer to save my login credentials. This is quite annoying, since the requirements are quite hefty (10 characters minimum + upper-case/lower-case mix + numbers + special characters.)
I do apologize -- As with lots of other websites, I've had to battle a lot of hacker break-in attempts, as well as spammers trying to spam comments. So I've had to strengthen the logins very significantly. There were some side effects of several of these modifications. Especially with all the security problems going around lately.
I will try to make some adjustments to make it possible to save login credentials; but it may now be time to consider a password manager (e.g. 1Password, etc) since it is gradually becoming necessary, with hackers now able to crack so many passwords lately. It even lets you create 30+ character random passwords that automatically get pasted automatically, unique password per website, and gets cloud-synced between all your PCs/Macs/iPads/iPhones/Android devices.
I know, I hate it, too! They break into one website, crack passwords for many logins, and try the same logins on other websites. It's no longer safe to reuse the same password like one used to on many sites. Most websites, including Blur Busters, get hundreds/thousands of hacker breakin attempts per day, using pre-cracked credentials from other websites broken in. (e.g. if your Macy account got broken into, they're probably trying to log into Amazon/Walmart using the same credentials, etc). As a result, Blur Busters no longer allows simple passwords.
I'm investigating other options in the longer term, to make the logins easier; including possibly automatically allowing Google logins / Facebook logins / Disqus logins. That said, this may take a few months.
