Setup 400Hz on 480Hz Monitor
[email protected]
Post by [email protected] » 20 Mar 2025, 03:27
Hello,
i have the ASUS ROG Swift OLED PG27AQDP, 26.5" with 480Hz.
I would like to setup 400Hz via CRU but in the CRU i can´t setup above 367Hz.
How can i setup 400Hz? Any idea?
Re: Setup 400Hz on 480Hz Monitor
Post by RealNC » 20 Mar 2025, 05:43
Can't you copy the existing 480Hz mode and tweak it?
[email protected]
Post by [email protected] » 20 Mar 2025, 07:15
RealNC wrote:
20 Mar 2025, 05:43
Nope, the 480Hz are already marked red.
It seems like the maximum programmed Hz in the CRU software are 367Hz.
Is there any walkaround?
The sourcecode is public, could someone code more Hz in the software for me pls? :D
Post by RealNC » 20 Mar 2025, 07:17
[email protected] wrote:
20 Mar 2025, 07:15
If the extension block is DisplayID 1.3, try changing it to 2.0 instead. Does that allow higher Hz? Might not work on Windows 10 though. I think DisplayID 2 is only supported in Windows 11.
[email protected]
Post by [email protected] » 20 Mar 2025, 07:42
RealNC wrote:
20 Mar 2025, 07:17
I have win11 and the extension block is DisplayID 2.0 :(
nuninho1980
Post by nuninho1980 » 21 Mar 2025, 09:02
20 Mar 2025, 07:42
What's your videocard?
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC <3 :D
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: CRT 19" Samtron 96BDF :|
[email protected]
Post by [email protected] » 21 Mar 2025, 14:48
nuninho1980 wrote:
21 Mar 2025, 09:02
20 Mar 2025, 07:42
6900xt
I tried to create new resolution but it´s not working.
https://imgur.com/a/RCPGHfW
Post by RealNC » 21 Mar 2025, 16:01
20 Mar 2025, 07:42
I just tried it myself and it works fine, even with DisplayID 1.3:
Are you sure you're using the latest version of CRU? (1.5.2 as of this writing.) Or maybe you're trying to add this in the main section rather than in the DisplayID extension block? You need to double-click the DisplayID extension block, and then in the window that opens, double-click the "Detailed resolutions" entry to be able to edit or add high refresh rate modes.
[email protected]
Post by [email protected] » 24 Mar 2025, 06:49
RealNC wrote:
21 Mar 2025, 16:01
Thank you for your screenshot. Now i got it and it´s working. ;D
