Blur Busters Forums
LG 34UC79G-B Ultrawide 144Hz - adjust strobing?
Postby GitDat » 17 May 2017, 21:33
I just picked up an LG 34UC79G-B Ultrawide monitor. An IPS/144Hz with strobing! The only thing is with strobing enabled, the screen is a bit too dark.
Is there any way to adjust the strobing like with BenQ monitors to help brighten up the screen? Thanks!
ASUS X99-Deluxe | 5930k @ 4.5GHz | 32GB G.Skill Ripjaws V 3200MHz | SLI GTX 1080 Ti's | Samsung 960 Pro NVMe M.2 SSD | 3DMark Fire Strike Ultra - 13,780 | Windows 10 Pro 64-bit | Nvidia Surround® 3 x BenQ XL2735 | LG 34UC79G-B Ultrawide Auxiliary Monitor
GitDat
Re: LG 34UC79G-B Ultrawide 144Hz - adjust strobing?
Postby GitDat » 18 May 2017, 20:30
What happened to the Blur Chief? :(
GitDat
Postby Chief Blur Buster » 19 May 2017, 00:09
GitDat wrote:What happened to the Blur Chief? :(
I'm certainly around! Much more so nowadays. ;)
...That said, definitely excuse my abscences of a few days, working on demanding projects. :ugeek:
GitDat wrote:I just picked up an LG 34UC79G-B Ultrawide monitor. An IPS/144Hz with strobing! The only thing is with strobing enabled, the screen is a bit too dark.
The LG is not as flexible, alas. You can max the ULMB Pulse Width (100%) & Brightness (100%) -- but that's about it.
P.S. Welcome back! :)
To support Blur Busters: Official List of Best Gaming Monitors | G-SYNC | FreeSync | Ultrawide
Postby RealNC » 19 May 2017, 00:14
Well we don't have every monitor out there. If there's no setting in the OSD to increase "pulse width" or "scale", then I'm afraid that 's the brightness you're gonna have to live with.
Postby GitDat » 19 May 2017, 06:13
Thanks y'all! Yeah, I don't see a pulse width setting anywhere :( Is this the only 144Hz Ultrawide monitor with strobing?
GitDat
Postby RealNC » 19 May 2017, 07:14
There's probably more. G-Sync monitors usually support ULMB, and ULMB usually offers a "pulse width" setting. In my case, if I set brightness to 100%, I actually have to lower pulse width, otherwise it's too bright. It really depends on the monitor.
But always double-check to make sure. "Usually" does not mean "always" :-)
Postby GitDat » 19 May 2017, 08:30
It looks like the Acer Predator Z35 Ultrawide does 200Hz and 3D :o I found this on the ULMB pulse width searching Google. Not good because I game at 120Hz :(
"The ULMB feature is accessible from the 'setting' section of the OSD menu. It is only available when running the screen at 85 and 100Hz modes. When you enable the ULMB feature a new option appears in the OSD menu if you drill in to the ULMB option. This new setting allows you to adjust the "Pulse Width"."
GitDat
Postby GitDat » 19 May 2017, 09:22
Perhaps these Ultrawide's just don't get as bright as my BenQ XL2735 with motion blur enabled :( It seems the LG is brighter than the Acer.
Max Normal Luminance and Max Luminance Blur Reduction On
Acer Predator Z35 120Hz 359 111
LG 34UC79G 144Hz 267 141
GitDat
Postby RealNC » 19 May 2017, 09:48
Yeah, 111 is way too low (unless you're using the monitor at night, and even then...)
I don't know why (and if) that's an issue with ultra-wide though :-/
Postby GitDat » 20 May 2017, 07:22
I can't believe I'm saying this, but this monitor is actually reasonable without blur reduction enabled. Here's a shot of the final product :)
GitDat
Next
Return to Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
Who is online
Users browsing this forum: No registered users and 1 guest
