Hey. I'm from Russla and my English is bad.
When I play the console, I get a lot of blurring (bifurcation). How do I configure my monitor so that there is no blur in the console?
For example, when playing in FIFA18-19, often a player is divided into 2 parts
HELP PLS!!!
playstation 4 + benq x2411z
Re: playstation 4 + benq x2411z
I believe the XL2411Z supports 60Hz single-strobe blur reduction. I don't know how to activate it though. On PC you would use the Strobe Utility.
Hopefully someone knows if this can be done with consoles.
Thanks, I hope. I hope to help meRealNC wrote:I believe the XL2411Z supports 60Hz single-strobe blur reduction. I don't know how to activate it though. On PC you would use the Strobe Utility.
Correct, XL2411Z supports single-strobe.
Yes, it works on consoles.
You can either use Strobe Utility or the Factory Menu to turn on single-strobe. If using Strobe Utility, you can disconnect the PC after and connect your console afterwards. If you don't have a PC, you can simply use the Factory Menu. Entering the Factory Menu instructions: viewtopic.php?f=13&t=2467
How to use the Strobe Utility function? how to enable it?Chief Blur Buster wrote:Correct, XL2411Z supports single-strobe.
Instructions: www.blurbusters.com/strobe-utility
