Blur Busters Forums
Acer G246HL stereoscopic option not showen help
Postby jonathah » 11 Aug 2019, 18:39
Got a acer GN246HL I want lightboost on it but in the nvidia
Control panel all stereoscopic options disapeared I know they were there before so I kno they can be there I got a gtx 1070
Help cant finalize the part with the 3d vision wizard :|
jonathah
Re: Acer G246HL stereoscopic option not showen help
Postby jurugi » 13 Aug 2019, 15:00
https://www.nvidia.com/en-us/geforce/fo ... installed/ You need to roll back drivers to install the unsupported 3d.
If the monitor is already showing the option for 3d vision/NVidia 3d then it's already on. (press middle button twice on the monitor to check). Once it's enabled you can usually just set lightboost thru the monitor, uninstall nvidia3d and not use it.
jurugi
Postby jonathah » 13 Aug 2019, 19:14
Hey I had already tried the 418 version but it didnt work
So I guess ill try a lower or 425
jonathah
Return to Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
Who is online
Users browsing this forum: No registered users and 16 guests
