Hello,
I use Benq XL 2411P and my new desktop(ryzen5 3600, rtx 2070 super,16gb ram 3200mhz) running WIN 10 PRO VL.
For example in Fortnite I use these settings:(low settings for smooth gameplay/ I locked game FPS at 144)
and my video started few weeks ago to look very bad, game is not playable anymore with those settings
Please ZOOM on images to understand:
The problem with glowing/flickering textures is also in CS:GO..
I bought new PC, new DP cable, I tried different drivers, but I still have that issue. I have to say that I haven`t changed monitor (XL 2411P) and the Windows 10 usb kit.
Please tell me what to? I should buy a new monitor?(Benq Gaming Xl2430) or try different settings?
Games video is a litle blurry/glowing/flickering textures
Re: Games video is a litle blurry/glowing/flickering textures
Have you enabled "Blur Reduction" in OSD of your monitor?
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC new! <3
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: CRT 19" Samtron 96BDF
HDD: SATA 1TB
Monitor settings -> Blur Reduction - OFF (is set to OFF)
Turn ON for almost eliminate motion blur. But...
- if you can't good enough reduction of motion blur and you get any "bad" crosstalk, see - https://blurbusters.com/benq/strobe-utility/
- if you want minimum crosstalk, see - https://blurbusters.com/faq/advanced-st ... stalk-faq/
HDD: SATA 1TB
HDD: SATA 1TB
