Thank youReverae wrote: ↑31 Mar 2022, 14:48Download the custom utility. Someone in YT posted this "I use a custom setting with a pulse width of 19 (which gives me about 100 nits of brightness). I think my pulse phase is at something like 82 , overdrive at 5, and vertical total of 4500. I get ZERO crosstalk at 60Hz and it looks absolutely amazing. "
Hello,Chief Blur Buster wrote: ↑19 Apr 2022, 23:24Personally I'd consider the ViewSonic XG2431 for even better zero-crosstalk results (using 120Hz with the VT2250 trick).SEA_mukilteo wrote: ↑18 Apr 2022, 16:23Can I expect no ghosting 3D stereo image with quadro graphic card / stereo 3 pin extension connector/active IR shutter glass and this viewsonic XG270?
Make sure the 3D glasses are correct polarization (vertical polarization versus horizontal polarization). IPS is polarized 90 degrees differently from TN screens, so shutter glasses for TN screens won't necessarily work unless you rotate your monitor by 90 degrees to portrait.
I had chance to test ViewSonic XG2431 with active IR shutter glasses(XPAN 105-IR-X1 / for general 3D TV).
The test environment are like followings:
- Prepared side by side green/blue image @120Hz(sView)
- Quadro RTX 5000 with VESA stereo 3 pin extension connector
- Set PureXP as "Ultra" in ViewSonic XG2431
Observation
- No blur image on each left/right lens of IR shutter glass
- No polarized issue, it was same as TN screens
Question
Do you know why no polarized issue on ViewSonic XG2431?
Thanks,
- PureXP set up
- ViewSonic_XG2431.jpg (3.61 MiB) Viewed 357 times
- ViewSonic_XG2431_IR_shutterglasses.jpg (2.63 MiB) Viewed 357 times
- Side by side (Blue/Green)
- test-image-LBlue-RGreen.jpg (73.02 KiB) Viewed 357 times
This is because XG2431 polarization direction is 90-degrees different from most TN screens. That makes it compatible with different shutter glasses, like repurposed DLP shutter glasses.SEA_mukilteo wrote: ↑05 May 2022, 12:32Hello,Chief Blur Buster wrote: ↑19 Apr 2022, 23:24Personally I'd consider the ViewSonic XG2431 for even better zero-crosstalk results (using 120Hz with the VT2250 trick).SEA_mukilteo wrote: ↑18 Apr 2022, 16:23Can I expect no ghosting 3D stereo image with quadro graphic card / stereo 3 pin extension connector/active IR shutter glass and this viewsonic XG270?
Observation
Question
- Shutter glasses uses LCD shutters which don't work well with wrong-polarized light.
- DLP emits unpolarized light (compatible with all shutter glasses)
- TN emits polarized light (compatible only with certain shutter glasses)
- IPS emits polarized light 90 degrees different from TN (compatible with DIFFERENT shutter glasses)
So shutter glasses must be compatible with the LCD's polarization.
You can also rotate a screen between portrait/landscape to fix polarization compatibility issues, since TN and IPS are polarized differently. IPS polarization is apparently more compatible with DLP-glasses polarization, because LCD inside shutter glasses don't work well with wrong-polarized light.
You found one of the best kept secrets: Today XG2431 is one of the best tiny 24" 3DTV-compatibles ever released -- near perfect zero crosstalk with the 120Hz VT2250 trick in ToastyX -- then re-calibrated with ViewSonic Strobe Utility to hide the room-temperature-sensitive part of crosstalk (temperature of summer/winter can worsen 3D glasses crosstalk).
I found that XG2431 PureXP is compatible with most DLP-Link glasses, with a "DLP-Link emulator" that has a shutter phase adjustment. And then using 3rd party 3D players that uses sequential-frame.
Voila. Perfect 3D from XG2431 that is superior to most 3DTVs and even better than NVIDIA 3D Vision!
It's very hard to setup, but I've been thinking of creating an open-source adjustable Arduino DLP-Link emulator box. That can turn most strobed LCDs into 3DTVs. It requires adjustable shutter phase, to compensate for refresh-delay difference between LCD and DLP, but other than that, it works perfect to use DLP-Link glasses with many strobed LCDs.
I imagine it'd work great with VorpX (enables 3D in video games), to turn XG2431 into a 3D Vision clone, usable with any generic DLP-Link glasses with compatible polarization.
Actually, I'll post an open source prize pot for this.
Bounty prize offer: $200 USD paid to first forum member who can package a working open source VorpX + DLP-Link solution for ViewSonic XG2431
Requirements:
- DLP-Link glasses (cheap at $10 each)
- DLP-Link emulator (simple arduino box, I recommend Teensy 4.0 since it supports 0.125 microsecond USB 8000Hz for accurate sync)
- ViewSonic XG2431 monitor
- Viewsonic Strobe Utility
This probably won't need any changes to VorpX, however, if any is required (to sync between the DLP-Link emulator arduino over a USB cable), that code also needs to be contributed as open source to the VorpX team as a possible VorpX plug-in.
Bonus: Adjustable shutter-open-length per eye, and adjustable shutter-open-phase (relative to VSYNC signalling over USB cable to DLP-Link emulator box from Windows D3DKMTGetScanline() to monitor VBlank events). That should make it compatible with almost all strobed monitors, assuming compatible polarization.
To support Blur Busters - see Multiple Lists of Best Gaming Monitors
How is the strobe crosstalk of the XG270 at 75 Hz? Is there any pursuit-camera photo/video?
