I feel motion reduction,need some help
When my fps goes to 70-75, i feel motiton reduction.im using an AW2521h.Am i doing something wrong?g sync is enable only for the game v-sync and triple buffer is off.overdrive is at lower-fast.what can i do to have low latency like high fps but to not feel the reduction on lower fps?
Re: I feel motion reduction,need some help
Please try to be more clear. I struggle to understand what you're asking about.
If your monitor supports backlight strobing/BFI for blur reduction, you should have the v-sync ON (tripple buffer can be off as long as you can maintain the framerate without it enabled) and your framerate should be completely locked to your refresh rate, 60fps at 60Hz, 75fps at 75Hz.
If you cannot achieve that, using motion reduction (strobing) won't be worth using IMHO.
no i was i feel like shuttering, like the g-sync not work properly with lower than 80hz.overdriver think that solving my issue.im keep testing
