XL2420TE +Chrome+Lightboost= 60hz ufotest
kyente
Post by kyente » 21 Jun 2014, 20:31
I don't know what i'm doing wrong! I have the monitor, I installed correctly, and rebooted. But when I go on the ufotest.com it says 60 refresh rate and frame rate 60. I make sure Aero is installed and since i'm using Chrome it shoudn't be a problem. I have a Nvidia GTX 760 and my computer settings are set to 120hz. Is there anything i'm missing?
Re: XL2420TE +Chrome+Lightboost= 60hz ufotest
Post by Chief Blur Buster » 22 Jun 2014, 02:35
Check requirements at www.testufo.com/browser.html
A common culprit is power management, which also occurs on desktops. Try setting Full Performance and seeing what happens.
xilanix
Post by xilanix » 29 Jun 2014, 12:58
The same thing happens to me, except that often it will initially say 120hz and have lightboost enabled, but after awhile I go back to test it again on the website and its switched back to 60hz. Any idea what may be causing that to happen? I have it forced to 120hz so I dont really understand how that makes any sense.
mello
Post by mello » 29 Jun 2014, 14:07
Download this Chrome version (30.0.1599.101).
Ufotest will work, even when you have Aero disabled and Windows Power plan set to" Balanced".
