I wanted to tryout ulmb on the 360hz, I realize that means I have to use 240hz. What other settings do I need to do in control panel, low latency, and as far as fps do I cap it or let it fly high?
This is for Csgo, I can get 500-600 constant.
360hz Alienware ulmb
Re: 360hz Alienware ulmb
for CSGO i'd say go for fixed refresh rate at 360hz, let the fps run wild.
Or if you wanna use ULMB or try it out (it won't do much for a game where tracking isn't that used as much) let fps run wild + the lower Pulse Width the clearer the image at the downside of lowered brightness.
