Lightboost with two monitors
Hi all, new VG248QE owner here. I've recently activated lightboost on this monitor with a second monitor at 60hz plugged in. Despite the other monitor, I was getting 120hz on the lightboost motion test with zero stutter. Although this fluidity did not last with the second monitor. Now I can't even achieve a steady 60fps along with severe stutter during the test, but, as soon as I unplug my 60hz monitor I get a solid 120hz with no stutter. I know its suggested to use only one monitor, but is there any kind of work around for this? There is no way I can use one monitor while out of game..
Re: Lightboost with two monitors
Did you make the vg248qe the primary monitor?
Yes, the vg248qe is set as my primary.
