Zowie XL2411P 144Hz 24" at 300 FPS??
whitebox
Post by whitebox » 16 Mar 2023, 11:16
Hi, first a little background:
I mainly play Apex Legends (which is limited by it's engine to 300fps). The hardware I have (3070Ti + 13600KF + 32gb DDR5) reaches between 250 FPS to 300 FPS depending on how many stuff is happening at the moment, but 80% of the time im at 299 FPS.
My actual monitor is XL2411P 144Hz 24" with the following settings:
AMA: OFF
Instant Mode: ON
Sharpness: 6
Blur Reduction: ON
Black eQualizer: 9
Brightness: 100
With this setup, how should I go regarding my FPS cap in the launch options of the game? NVidia reflex ON? ON + Boost?
Any other recommendations to improve my motion clarity and minimize my latency?
Note: Next month I am getting a XL2566K 360Hz DyAc⁺ 24.5
kyube
Re: Zowie XL2411P 144Hz 24" at 300 FPS??
Post by kyube » 18 Mar 2023, 14:22
whitebox wrote:
16 Mar 2023, 11:16
AMA: OFF
Instant Mode: ON
Sharpness: 6
Blur Reduction: ON
Black eQualizer: 9
Brightness: 100
The only way to improve from 144hz sample and hold blur is by either getting a refresh rate increase (as you're already doing) or going the strobed route.
I'm not sure how the XL2411P performs when it comes to strobing, but you could attempt fiddling with DyAC (perhaps with the QFT trick at lower refresh rates if lower modes don't double strobe)
Other than that, no improvement is possible.
