So I have been playing around with the custom settings using the strobe utility etc and its pretty good.
I wonder if its possible to get any better than this: (mine is slightly not as bad but its the only example I can find.)
That slight after image still remains no matter how much I change the crosstalk, is there anything I can tweak to improve this or is it a limitation of the monitor?
Can I get any more out of the XG2431?
Re: Can I get any more out of the XG2431?
Which refresh rate are you strobe-tuning?
If you use refresh rate headroom and large vertical totals, you can get much better.
You can get the below at 60-100Hz range using refresh rate headroom + large vertical total:
- Tiberiusmoon
Max refreshrate.Chief Blur Buster wrote: ↑31 May 2023, 05:33Which refresh rate are you strobe-tuning?
Monitor adaptor and NVCP says 240Hz but Advanced display say 239.76.
I could go for around 200Hz if there is any benefits in doing so.
- Tiberiusmoon
I saw a vid on how to Nvidia tracks motion blur so I tried it out freehand:
Ignoring the blurryness ofc, you can see the after image I see.
Also, I tried running 60Hz and 120Hz the afterimage visibility is reduced but not completely gone.
XL2566K can achieve zero crosstalk at 100Hz with QFT, so XG2431 should be able to achieve the same.
- Tiberiusmoon
The crosstalk improves a lot which spans the whole monitor and reduces after image visibility quite a bit aswell @120Hz and 100Hz.
The after image spaces out further behind the lower the refreshrate.
For some reason the monitor does not want to display 60Hz.
The TestUFO built into Strobe Utility pans a bit slow sometimes, so you can spacebar-disable it, and instead use www.testufo.com/crosstalk at 1920 pixels/sec as the background. This allows finer strobe adjustments, that can eliminate even more strobe crosstalk.
Video is a form of burstshoot that makes it easy to find good freezeframes out of multiple attempts (simply by thumb-scrubbing through the resulting video to find the best frames)
Improved freehand instructions:
New Easy Free Pursuit Camera: Hand-Wave Smartphone. No rail needed.
NVIDIA's robot arm pursuit camera is accurate thanks to some electronic help (LDAT blips) but to do freehand by human eye, requires the sync verification test pattern (horizontal ladders).
Do this on this URL:
www.testufo.com/ghosting
Pursuit camera becomes more accurate/clearer/easier if you use the Sync Track -- and if you use 4K video. Even easier if you use a third party video app (DSLRCamera for iOS) and configure its fixed exposure to approximately 4x refresh cycle.Tiberiusmoon wrote: ↑31 May 2023, 07:06I saw a vid on how to Nvidia tracks motion blur so I tried it out freehand:
Try large-VTing ~65-70Hz, and then once you successfully do that, then change radio button to Hz, and simply edit the Hz down without changing the VT. You'll get something like VT ~4200
There's been many reports that VT 4500 is only possible on some video ports (not all of them), but the data is a little uncertain.
- Tiberiusmoon
I think I understand the method.Chief Blur Buster wrote: ↑02 Jun 2023, 03:47Try large-VTing ~65-70Hz, and then once you successfully do that, then change radio button to Hz, and simply edit the Hz down without changing the VT. You'll get something like VT ~4200
I tried maximizing the the pixel clock ranges to get the highest VT within range like so:
So I did the same for the lower refreshrates then reduced the VT until the monitor is able to run it without blackouts.
It has reduced it quite a bit but its so faint that its noticable in real applications.
Hey, bud. Does this not reduce your color to 6-bit or 6-bit +frc so it would read as 8 bit in windows? It appears that the monitor doesn't like the horizontal sync in the upper 270 khz range going down to 60hz. I managed upper 4400's tvl with I believe 272khz horizontal and kept the bandwidth down far enough I got to keep the 8-bit+frc color.Tiberiusmoon wrote: ↑02 Jun 2023, 18:24I think I understand the method.Chief Blur Buster wrote: ↑02 Jun 2023, 03:47Try large-VTing ~65-70Hz, and then once you successfully do that, then change radio button to Hz, and simply edit the Hz down without changing the VT. You'll get something like VT ~4200
