Acer Predator GN246HLBbid 144Hz
Hi, i have a question, how do i activate "lightboost" on this screen? and any ideas why i cant use the "built in" "autosize" and scaleing functions? it just stays fullscreen even when plugging it in and out of my computer and all settings in nvidia control panel are correct, thanks!
Re: Acer Predator GN246HLBbid 144Hz
Try Strobelight LightBoost Utility. I've set 144Hz, installed it, rebooted, and after reboot changed to 120Hz and LightBoost worked IIRC. There is scaling options in monitors OSD.
http://www.monitortests.com/forum/Threa ... and-NVIDIA
Ok so how do i change the percentage i want then? and it's better to play at 120hz strobed then 144 non strobed ye?
Right mouse click on system tray iconheaheahea wrote:Ok so how do i change the percentage i want then?
Try both. It's personal.heaheahea wrote:and it's better to play at 120hz strobed then 144 non strobed ye?
As far as I know, StrobeLight doesn't support GN246HLBbid -- so another method of LightBoost is needed.
In theory, someone could lend an Acer GN246HL to ToastyX to get it to work with Strobelight. Each monitor has a manufacturer-specific modification to its LightBoost protocol, so it is not an easy task to make LightBoost enabled in a third party utility.
