Lightboost and Custom Res Same Time
Hello. When i use lightboost on vg248qe brightness is too low. Its fine but when i put 1350x1080 or 1440x1080 res lightboost does disappears. Is there a way to use both of them at same time?
Re: Lightboost and Custom Res Same Time
Try forcing GPU scaling in your GPU driver control panel. This way, the monitor will always run at 1920x1080 and the custom resolutions will be scaled by the GPU, not the monitor.
But when i do that even on desktop res does look garbage its night and day difference. I just want display scaling and lightboost at same time if its not possible its fine
