I picked up an Acer XB273UF and it got me thinking, does ULMB2 work (or work well) when you can't sustain 360fps in your gaming? Say you're averaging 200fps or even 150?
I poked around the forum and failed to find an answer, apologies if this has been covered already.
ULMB 2 effectiveness when not hitting 360fps?
Re: ULMB 2 effectiveness when not hitting 360fps?
It works fine if you prefer low latency (esports, competitive, etc).Snapzilla wrote: ↑07 Aug 2023, 10:27I picked up an Acer XB273UF and it got me thinking, does ULMB2 work (or work well) when you can't sustain 360fps in your gaming? Say you're averaging 200fps or even 150?
But if you're quality-priority, remember framerate=Hz is better quality.
So the lower frame rate during max, the more duplicate images you will get. (This is not strobe crosstalk -- it is extra above-and-beyond strobe crosstalk).
The main fix is to intentionally lower the ULMB refresh rate to be closer to your refresh rate territory, if you are quality-priority over latency-priority.
120fps=120Hz strobing is better quality than 200fps-at-360fps strobing, so sometimes there's a handiness to lowering refresh rate to get your needed stroberate=refreshrate=framerate if you're quality-priority over latency-priority.
If you're sensitive to tearing like me then it's terrible compared to running 360hz g-sync.
Good feedback and info, thank you!
I hate tearing, but it seems less obvious (or I'm less prone to noticing) when the fps is 200+. That being said I've been using both modes off and on and have a hard time telling the difference in various games I play; the motion clarity is pretty good in both settings but i think I am sticking to gsync to prevent tearing and get the best quality I can as I'm not driving this at 360hz locked fps.
