Hi,
I thought I'd post an issue I'm having with my monitor here as it seems like its related to blur reduction in some weird way. Now I don't personally use blur reduction anymore these days as I find it makes this panel too dark but I have in the past. For a while now I have an issue where when I turn my screen on the image looks ok for about 2 seconds and then suddenly becomes washed out. Its hard to explain but its almost as if the backlighting is cranked to the max but the brightness of the pixels stays at blur reduction levels. Making the image look washed out and ruining contrast. It almost as if my screen is coated in vaseline. However when I turn on blur reduction and then turn it off again the image returns back to normal. Problem is that everytime i turn the entire screen off and on again the issue is back.
Hoping anyone out there knows what the issue might be.
XL2730Z contrast issue
Return to “Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
