So Im doing the alien invade test and this is what you get:
http://imgur.com/lf0KjFb
This is not my monitor but its looks similar.. Took pic from this post:
http://www.overclock.net/t/1505130/xl24 ... e-ghosting
Im using blur buster strobe utility and no matter the settings this ghosting is always visable.. I havent tried the settings AMA and instant mode on OSD.
IS there anything I can do to get rid of this?
Does all xl z benq monitors suffer from this?
xl2420z ghosting
- masterotaku
Re: xl2420z ghosting
The AMA setting is precisely what affects this issue.kilos wrote:I havent tried the settings AMA and instant mode on OSD.
You can't get rid of it, but you can change it so it looks different.kilos wrote:IS there anything I can do to get rid of this?
- AMA off: regular ghosting because the panel isn't fast enough to change colors.
- AMA high: inverse ghosting caused by overshooting. The panel tries to reach the color target much faster than normal, so it ends up failing to stop when it has to.
- AMA premium: lol, don't even try that. It's worse than AMA high. No benefit.
- Using Lighboost: a lot less overdrive artifacts, but worse colors, screwed up gamma, only 100Hz and 120Hz, minimun strobe is 1.4ms.
- AMA high after using Lightboost: different to normal AMA high. Better or worse depending on the situation. I use this in more or less 60% of the games I play.
Yes. Unfortunately, this is unavoidable. But this is the only monitor in the market that allows me to have this many refresh rates, all with blur reduction:kilos wrote:Does all xl z benq monitors suffer from this?
If only the Asus PG278Q were capable of this....
Monitor: Asus PG278QR
Tried to change AMA settings, Off was NOT Good.
High is the best option for sure.
IF ONLY This ghosting didnt exist.. this monitor would be perfect
I don't notice this in games at least, thankfully.
Cougar Conquer 2 | MSI Meg Z390 Godlike | 9900K | NZXT Kraken X72 | 32GB TridentZ RGB 3600MHz | RTX 3090 FTW3 Ultra | Samsung 960 Pro NVMe M.2 SSD RAID-0 | Corsair AX860 | 3DMark Port Royal - 14204 | Windows 10 Pro 64-bit | Triple 32" Samsung CHG70 | Samsung CHG90 Super-Ultrawide Auxiliary
kilos wrote:So Im doing the alien invade test and this is what you get:
My entire review of my XL2411Z + Other gaming monitors is a good thing to look at for you: http://forums.blurbusters.com/viewtopic ... 11z+review
Hope it helps!
