Hi Guys,
has someone tested LightBoost hack on the Acer Predator XB270Hbmjdprz?
It is not on the supported monitors list because the release was fairly recent.
I may order it and just try CRU Method with it or are there other "general" methods to force LightBoost on unsupported Monitors?
Lightboost Acer Predator XB270
Re: Lightboost Acer Predator XB270
GREAT NEWS GUYS!!! I can confirm the CRU Method works with this display!!!
Nice, and how it looks in compare to ULMB? (image/colors quality and motion)
Anyway nice for current amd gcards users.
That's the XB270HB[...] model, which doesn't support ULMB. The XB270HA is the one with ULMB.Alamar wrote:Nice, and how it looks in compare to ULMB?
Yes, the CRU method works.schnip wrote:GREAT NEWS GUYS!!! I can confirm the CRU Method works with this display!!!
Once it works successfully, then ToastyX Strobelight can be used as a method of turning it ON/OFF. (once LightBoost is successfully turned on at least once by a different method). Strobelight doesn't support first-time initialization of LightBoost, but it can control ON/OFF once it's successfully turned ON, at least until the monitor is unplugged from the power outlet.
Could you explain how exactly you activate Lightboost on this monitor?
Greetings
Greetings
