Hello,
I just setup strobelight and it seems to work okay. But I only see the 30FPS and 60FPS ufos on the test page, is that normal?
I have the BENQXL2411T and the AMD R9 280 with the CCC 14.7 driver, since 14.9 is not working with strobelight yet. My monitor is obviously running on 120hz and strobelight is on. Thanks for help.
120hz not visible in ufo test
Re: 120hz not visible in ufo test
make sure you're not using the windows 7 basic theme or whatever
you need aero compositing for it
