LightBoost Issues
SightUp
LightBoost Issues
Post by SightUp » 03 Feb 2014, 23:23
I posted this over @ OCN.net, too. But I didn't know that you guys had a forum up and running now.
I am having a problem.
I unplugged everything for a few hours while I was moving into a new room. When I hooked everything back up, started the computer, the LightBoost will no longer work.
I have rerun strobelight-setup.exe and did the reset display (uninstall) option but this had no effect.
What should I do?
Q83Ia7ta
Re: LightBoost Issues
Post by Q83Ia7ta » 04 Feb 2014, 08:21
After strobelight-setup.exe you need reboot and run strobelight.exe. How long did you wait after running strobelight.exe?
SightUp
Post by SightUp » 04 Feb 2014, 12:14
I got it working!
I had no idea what strobelight.exe did. When I first installed windows, I just ran strobelight-setup.exe and it worked.
