MICk42 wrote:The main thing I want to emphasize: the 60 Hz flicker is really not too bad, contrary to how it appeared to me at the beginning! As one looks at the completely white screen in Windows, it might seem horrible at first, but as I got used to it and played some games, I found out not only currently I have no problem with the flicker whatsoever
Exactly!
Same for me.
Again, I hate to sound like a broken record about 60Hz strobe, but I will repeat again, and say it again:
LCDs are bigger than yesterdays CRTs - Amplfies Flicker
The problem is in the variables.
- LCD today is bigger than CRT yesterday. Meaning flicker amplified
- LCD today is brighter than CRT yesterday. Meaning flicker amplified
- LCD flash all at once versus CRT scan top-to-bottom. Meaning flicker amplified
- Room lighting
- Bright content versus dim content
- Viewing distances
- Etc.
Again, you can control some of the variables.
Controlling Most Of The Flicker Variables
Setup your LCD like you might like an older CRT:
- Adjust room lighting to balance things out (many advised against CRTs in totally dark room)
- Use dimmer content (many games are darker than Windows desktops)
- Don't sit too close like you didn't with CRTs (sit slightly further back)
- Don't use low-Hz strobe at Desktop with your bright browser windows (raise refresh rate when back to Desktop, or turn off strobe)
..........And 60Hz single-strobe is MUCH more tolerable.
Yes, it's slightly more flickery than an equal-size CRT due to all-at-once-flash versus scanned inpulsing (an electron beam is always illuminated something somewhere on the screen, for more consistent light output). But once you exercise some common sense, it's only about ~10%-20% more flickery in feel of an equivalent-size CRT at equivalent brightness at equivalent viewing distance.
Again, 60Hz strobing can be made tolerable with many adjustments.
So... It's really mainly painful with bright browser windows but perfectly fine to my eyes for certain kinds of emulator games, brightness adjusted, viewing distance adjusted, etc.
Manufacturers...
So.... Manufacturers need to add 60Hz single-strobing option! (Looking at all of you manufacturers).
Even RTINGS.com
decreases review scores of HDTVs and monitors that do not have single-strobe 60Hz, it's a checkbox in all RTINGS reviews nowadays!
Some laboratories at manufacturers don't test 60Hz single-strobe correctly to evaluate it in a more favorable environment. Setting up the screen on a lab bench and then maxing out brightness, using Windows calibration software, and then they decide to disallow firmware from working with 60Hz single-strobe. It's all common sense, really.
DUH!
