Blur Busters Forums
1440p Advice, XL2730/35 blur reduction. Best options?
Re: 1440p Advice, XL2730/35 blur reduction. Best options?
Postby RealNC » 17 May 2017, 01:18
You can also try 165Hz. You can enable support for that mode in the OSD.
Postby Coexist » 17 May 2017, 08:41
RealNC wrote:You can also try 165Hz. You can enable support for that mode in the OSD.
My panel just shits in pants if I try 165z, wont accept the OC.
Coexist
Postby Coexist » 17 May 2017, 11:17
So I'm torn between
BenQ ZOWIE XL2730
Acer Predator XB241YU
Anyone have experience with these panels? Not fussed about g-sync. And am tempted to go back to 24" tbh.
1440p is a must, as is some sort of blur reduction tech for anyone wanting to recommend something else.
Many thanks,
Coe.
Coexist
Postby Falkentyne » 17 May 2017, 11:49
Avoid the XL2730. It's buggy.
The fixed scaler is in the XL2735.
Falkentyne
Postby Coexist » 17 May 2017, 12:19
Ok thanks,
Unfortunately the XL2735 is out of my price range as I wont be able to sell the Acer to cover the cost :( Expecting to loose at least £100 on it.
Coexist
Previous
Return to Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
Who is online
Users browsing this forum: Bing [Bot] and 2 guests
