I'm using lightboost with my Asus VG248QE monitor and a AMD R9280x graphics card.
When I activate lightboost the monitor ofcourse goes in 3D mode, but how do I disable this feature with an AMD card? I would like to use alle the monitor options available.
Also does anyone in here know of a setup to f.ex. SweetFX which corrects the dark and colorless screen - especially within Battlefield 4. The most guides about setting up your monitor og software is related to Nvidia cards.
Disabling 3D-mode with AMD card
Re: Disabling 3D-mode with AMD card
Are you trying to enable color adjustments while enabling LightBoost?Trilas wrote:When I activate lightboost the monitor ofcourse goes in 3D mode
Enabling LightBoost requires the 3D mode. LightBoost disables most adjustments so you won't be able to get your picture adjustments.
However, with newer official strobe backlights (ULMB, Turbo240 and BENQ Blur Reduction), they are enabled via monitor menus & you can adjust your monitor's colors.
