When my PC boots up strobe-light automatically is on. Is there a way to set it to Off, and then I can just turn it On for gaming when the time comes?
NM: strobelight-off.exe = will start-up with it off.
Startup [With LightBoost OFF by default?] [Fixed]
- BTRY B 529th FA BN
Re: Startup [With LightBoost OFF by default?] [Fixed]
Yep, ToastyX informs these instructions at monitortests.com:
http://www.monitortests.com/forum/Threa ... and-NVIDIA
Options for strobelight.exe:
The program can be configured by renaming strobelight.exe to any of the following:
- strobelight-init.exe = Initialize any monitors if necessary and quit. It will not stay running in the background. Keyboard shortcuts will not be available.
- strobelight-hide.exe = Hide the tray icon. It will stay running in the background to handle keyboard shortcuts. You can use the task manager to end the process.
- strobelight-off.exe = Start with strobing off. This can be combined with the other options: strobelight-off-init.exe or strobelight-off-hide.exe
