2d light boost across 3 asus monitors possible?
Hello all. Title says it all. I've got 3 144hz asus monitors hooked to a 7970. I was under the impression that it would work across all 3 monitors. I've had someone tell me it will not work across all three screens which I find odd. Can anyone confirm this for me and also is there a way to test it across 3 screens? Thanks.
Re: 2d light boost across 3 asus monitors possible? [Yes]
It will work across all 3 screens, if you use ToastyX Strobelight. Strobelight was made as a utility to make that easy -- and has actually ironically been easier to do surround LightBoost on Radeons than on GeForces (due to some changes to surround made in certain drivers).torsionbar wrote:Hello all. Title says it all. I've got 3 144hz asus monitors hooked to a 7970. I was under the impression that it would work across all 3 monitors. I've had someone tell me it will not work across all three screens which I find odd. Can anyone confirm this for me and also is there a way to test it across 3 screens? Thanks.
