Does anyone have experience with the 24GM79 and its strobing? The old 24GM77 had a mediocre strobing implementation, but there have been unconfirmed improvements to LG's strobing since then.
After using an XG2401 for some time, I have decided that I cannot tolerate the motion blur of regular sample-and-hold image presentation...
LG 24GM79 strobing implementation quality?
Re: LG 24GM79 strobing implementation quality?
-- The best I've currently seen are NVIDIA's ULMB and Samsung's Blur Reduction.
-- BenQ Blur Reduction / DyAC are calibrate-able, so it can get really good after quite some manual tweaking (www.blurbusters.com/strobe-utility and www.blurbusters.com/crosstalk)
-- The rest (ASUS ELMB, LG Motion Blur, etc) are not calibrateable, and I've heard they're not as good.
Eventually, I look forward to having one monitor of each strobing technology during 2018 for strobing head-to-head tests. LG monitors are still great for many things, but if motion blur reduction is your numero uno priority...
espero que usted los consiga pronto
