Im having a hard trouble finding out if this is "normal" or not.
It really feels like its not.
When i "shake my head" or look quickly around in any fps game, i experience lag.
No matter the fps. It could be set to 60 or 144hz, on any graphic setting; low or ultra.
I experience the same either way.
I've attached a picture taken with my phone, taking several pictures per second in order to caputre what i am seeing.
I've tried ULMB, tried different refresh rates, different games, different settings in games (PUBG and Destiny 2), different drivers, G-sync disabled/enabled.
I jsut dont know if this is not the screen for me or what i should expect.
I expect the image to be smooth and clear as I am looking around. Not this ghosty blur..
What is it that i am experiencing?
How do i fix it?
PLEASE advice.
Thanks!
Specs:
Screen: ASUS ROG Pg279Q
GPU: MSI Geforce 970 SLI
CPU: i7 8700K
Lag/blur when looking around - FPS games - PG279Q
- blur2.PNG (192.82 KiB) Viewed 4464 times
- lexlazootin
Re: Lag/blur when looking around - FPS games - PG279Q
Check the OD or Overdrive setting, this controls how fast the pixels switch, the middle setting tends to be the best
https://testufo.com/ghosting
Thank you for your reply.
Tested all 3,no noticable difference and was set to normal to begun with.
Could it be that my panel is faulty?
Maybe take a video of it.
Video is a good idea -- that will help us determine what it may be caused by.
-- If it's normal (it may be)
-- If it's a monitor defect
-- If it's something else
Also, both IPS and VA will ghost much more than TN.
Your eyes may just simply prefer TN even if everyone else say IPS/VA is better.
Also, try ULMB with the triple lock needed for blurfree+stutterfree motion (stroberate = refreshrate = framerate). You will likely need to use possibly VSYNC ON). A lower framerate for easier triple lock. Try 100fps ULMB with temporarily VSYNC ON with one of your full-framerate games, and see what happens. Yes, VSYNC ON adds lag, but it will help diagnose if going simultaneously blurfree+stutterfree fixes the effect -- or not.
