My osd menu in the VG278Q monitor working fine but i cant use 2 functions in my Image menu
1.Aspect Control
2.ELMB
i cant enable or disable any one of them and i know i want to disable my ELMB
the functions is gray and all the other are white and i can enable or disable any one of them.
Btw i have gtx 1070 and this monitor using freesync so if that connected tell me.
ty
Cant disable ELMB in my VG278Q 144Hz 27INCH
Re: Cant disable ELMB in my VG278Q 144Hz 27INCH
Aspect ratio settings probably require you to run a non-native resolution first, and ELMB probably only works at specific refresh rates (like 120Hz.)
If you're using FreeSync then ELMB is currently disabled.
