Question about the AW2518HF monitor
PostPosted: 28 Nov 2018, 05:20
by Imgema
Just got the AW2518HF (Dell Alienware 25) and i'd like to know if there is any way to use any kind of blur reduction with it.
Since it's not the G-Sync variant there is no option in Nvidia. But it's 240hz and it has freesync so maybe there's something else i could use?
Re: Question about the AW2518HF monitor
PostPosted: 28 Nov 2018, 11:07
The Dell AW2518HF does not have a motion blur reduction feature.
If you're looking for a FreeSync monitor with an optional motion blur reduction feature, check out the "Motion Blur Tech" column in the List of FreeSync Monitors.
PostPosted: 28 Nov 2018, 15:03
by Imgema
Well, i already bought this one so it's too late for me to use that list. I just learned about blur reduction now, otherwise i would probably get something else.
So now i was hoping i could use a third party utility or something.
