Acer GN246HL
kingeryck
Acer GN246HL
Post by kingeryck » 06 Jan 2019, 21:12
So I was following this video https://www.youtube.com/watch?v=Lgzae7pH5BM and after I hit reset64, my screen went nuts. I could only see half the screen, and it was flickering like crazy and had these lines in it. I had to reboot and do the reset-all and restart64 numerous times to get it to where it looks normal. The LED on monitor is still green and I can't access the OSD. I still don't have 144 back as an option on the nvidia control panel How do I a) reset it completely or b) fix this?
When I tried instead following the instructions on the website, the 3d setup wizard made my display go nuts.
Re: Acer GN246HL
Post by Chief Blur Buster » 07 Jan 2019, 02:44
Try full unplug of monitor and replug.
Try running "reset-all.exe" that came with ToastyX.
Try another resolution such as 1024x768 or a low refresh rate like 60Hz -- using Windows.
I am not sure what happened to your monitor, but it may be a unit with a defective NVIDIA LightBoost.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
