AOC c24g1 problem with MBR
xabimike
Post by xabimike » 22 Feb 2019, 09:02
People, i need help)
I bought aoc c24g1 monitor, made settings like on pcmonitors, I'm happy with everything, normal fonts, no loops and so on.Overdrive is high, low blue-multimedia, MBR (motion blur reduction) - 10 out of 20.
BUT there was a problem that is very annoying:
When I turn off the computer and turn it on in the morning, the MBR is reset to 0, all other settings are saved. If the monitor is simply on / off, then the MBR remains at its value at 10.I really do not want to every time when you turn on the computer to climb the monitor menu and set the MBR.Tell me what the problem may be and what to do)
Q83Ia7ta
Re: AOC c24g1 problem with MBR
Post by Q83Ia7ta » 23 Feb 2019, 06:20
Your MBR value is controlled only by monitor so it's the problem. This issue can be fixed by firmware but monitor manufacturers usually do not let users to update firmware on their monitors. Deal with it or change monitor.
falke
Post by falke » 26 Feb 2019, 11:29
i have the same problem. i think the problem is, that by restarting pc the boot loading screen is at 60Hz. The MBR function is not supplied at 60Hz. The monitor turns off the MBR at 60Hz and keep it off although the refreshrate is back at 144hz.
But i dont have a solution for this problem. it would be greate if someone can help.
I have contacted AOC and waiting for answers.
Post by Chief Blur Buster » 26 Feb 2019, 14:12
Failing to save the MBR setting is often a monitor manufacturer quirk.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
